1 - 9 of 9 Posts
Well everyone I found the cause of the sudden oil consumption/engine seizure of my Kohler engine. I just replaced the engine with a Briggs a few minutes ago. While carrying the old engine to the junk pile I saw it! The crankcase vent tube is missing. It connects the rocker cover to the carb intake. Dirt has be sucking in a nickel sized hole straight to the intake! @#%&[email protected]#......I don't cuss! LOL Oh well, that's the way life goes sometimes. That's why it went from a few ounces of oil consumption after a few hours to 32 ounces in the same time. Oh yeh, for future reference , the Briggs replacement was plug and play.....that simple.
Discussion Starter #4
Jeep, Fish is probably correct that it just deteriorated and fell off. It is kind of a cheap design. It pushes into a hole on the rocker cover and carb intake. There is not a nipple of any kind. You would think that the designers would have made a nipple on such an important piece like this.
The rubber is very thin and oil seems to have an effect on it , Honda GX series have the same type of set up , on the Honda it goes from the valve cover to the intake
The kohler on my wood splitter has one of those hoses. I'm glad y'all brought this issue to my attention.
This is the hose in question ?? ..... I believe I'll order a replacement hose just in case, I'd be screwed if i lost this kohler plant!
Edit: i already see some oil residue, around the base where the hose goes in the valve cover.
think the hose may have been ""Made In China"" :smile
1 - 9 of 9 Posts
