21 - 35 of 35 Posts
If you're lucky, you MIGHT be able to save the grips. Throw the rest of that POS away! lol
Discussion Starter #22
Update...
OK, so here is where we are now....I did a compression test on the engine. It is good! 98 psi! I put a good battery in it and turned the key. The display came on! A small squirt of either and she fired right up! That was all I needed to know for now. I'm about to start the conversion now that I have it all tore down. I should have a rancher TE by morning if all goes well!
lol, I was making a joke, I thought it was funny that you hauled those tires and rims all the way back to your house though! :) Would he not let you take it without those? ha ha
Great project man!!! My kinda fun!!
well where are you getting the frame from. And all the other parts.
sweet i would of bought it and made something out of it or bought a rancher that was blown up and threw the motor in it i mean where yo gonna get a running rancher motor will all the electrical for $275 good find
thats the way i look at it. you probably would've paid $100 just for the wiring harness....great find
Discussion Starter #31
I've got a 2003rancher TM that the crankshaft went bad in. I've got the motor completely tore apart. The last part I needed to order was the crank. I was getting ready to order it a few days ago when I came across the 2000 model rancher TE. I figured I couldn't go wrong for 275. The odometer on the TE reads 4223 miles. I already had the motor out of the TM , so all I had to do was change out the wiring harness and all of the component's that the TE had that the TM didn't.
Discussion Starter #33
The beautiful part about it is I've already got everything to do a rebuild on this atv when it needs it. I bought a new piston kit, valves, gasket kit, valve seals, cam chain, and had the cylinder bored for the engine out of the TM.
Discussion Starter #34
The transformation is done. I now have a rancher TE! The only problem I had was with the wiring harness. The small plug that goes to the ecm and the plug that goes into the regulator/rectifier are the exact same size. They are Eben the same length comming out of the harness.the only difference is one has 5 wires and the other has 6. Well I got them wrong the first time. Hooked up the battery and instantly blew the 30a motor fuse! It took me a minute to figure out what I had done wrong, but I'm just glad it blew the fuse before it had a chance to do any damage.
21 - 35 of 35 Posts
About this Discussion
14 Participants
Manny
Honda ATV Forum
Full Forum Listing
