1 - 2 of 2 Posts
Hey. My break pads wont go in into the caliper. It seems like the brake pad is a bit thick. But ive seen on youtube how other people put the same thick pads in with no problem. What holds the break pads from going in are the 2 little bumps on the side in the caliper
1987 TRX250X
If you can't push the piston back to make more room, then put it in a vice, take out the bleeder screw, and put a socket on the piston and beat the crap out of it until it retracts all the way and then the pads should go in.
1 - 2 of 2 Posts
