1 - 20 of 23 Posts
jon and i were riding on the back roads pretty good speed an the 300 started making a grinding noise in the crank case before we got stopped she blewup motors is locked up big crack in bottom case plug gap pounded flat not sure what happened bu today we are installing a 98 300 motor i picked up from a friend when i get back to work we are going to look for a new upgraded motor or try to build one so i will need help frm all you guys on what specs to go to you all are so very helpfull so i guess it is R.I.P MONSTER the new motor smokes a little should i go ahead an put new rings in it :frown::redface:
It would probably be a little easier to put the rings in the engine while the engine is still off the frame.
that sucks.hopefully dont to long to get going again.
Sorry to hear about the monster, but the good nes is you have another engine on standby. I think I would run a compression test n the new engine you may just need to replace the valve seals. but never the less I think while it was frame off I would go ahead and freshen up the engine a bit, eg new piston and rings if the cylinder walls look clean and smooth you may get by with a rering?
you other engine sounds like you might have lost the oil pump and it siezed up the crank bearings and snapped the connecting rod.
We are here if you need any assistance good luck. let Jon know I'm sorry about the loss, I know it really dissappoints young children.
thank you all im busy wipeing jons tears away but this other motor i will go through it while i have it out :unsure:
Man that bites.Sorry to here that.I sure hope I never have to go through anything like that.
Discussion Starter · #10 ·
thank u guys this is jon and let me tell u what i am so upset because i was hopen on goen riden this weeken but i cant know
Discussion Starter · #11 ·
so sad i lost my baby
Yeah I know you were... sorry you and I didn't get to drag. but june is still 2 months away.
Look on the bright side. You can practice your typing skills in your down time. It will be a win-win for everyone. :icon_wink:
HAAAAAAAAAAAAAHHAHAHAHAHAHAH ROFLMAO!!!!!!!!! :rating10::icon_ owned::icon_ rofl::icon_ rofl:
Discussion Starter · #16 ·
hahaha pain i type just finne thank u vary much lol
:icon_ laughup::icon_ laughup::icon_ laughup::icon_ laughup::icon_ laughup::icon_ laughup::icon_ laughup::icon_ laughup::icon_
1 - 20 of 23 Posts
