1 - 20 of 23 Posts
hello first time posting on the site. i have a 03 400ex and going to bore it to a 426 i have a stage 2 hotcam big gun rev box white brothers e-series slip on exhaust im having gt thunder hd head studs installed and a 88mm wiseco 11:1 piston and have the head mating surface trued up and a port and polish atm with a 10:1 piston stock bore i have 168/42 jets in the carb with choke removed and an opend air box with a k&n airfilter with a precharger need a little help on starting position with the jets ive read alot of forums and think a 180 185 and 190 should be what i try any advice?
I'm sure slammed ranger will be along to talk jetting with you, he seems to have it down to a science from what I've read....
45 pilot jet. And 185-190 main jet would be a place to start. Your gunna want to put the needle down one clip also. And i suggest some sort of cooling mods or your gunna run the risk of over heating. Are you doing a bore on stock sleeve? Or having the jug sleeved with a LA sleeves and then bore? Welcome to the forums!
thanks for the help and im allready 1 clip down on the slide pin and i bought a bored stock cylinder and a 11:1 wiseco 88 mm piston and the cooling i have air fins and an oversized oil tankand i am putting a spal fan on the rad with a thermo switch for automatic cooling no idea what else to do atm unless i put an extra rad on it and a 45 pilot will i really need to go that big?
Oh yeah. I was running a 45 in my carb when i had a stock carb. And mine is a 416ex. Stage 2 cam. And +1 valves. I wouldnt be surprised one bit if your 426 needed more. But i would think 45 should cover it.
Your cooling mods will be plenty sufficiant. Though. I have very similar just no over sized oil tank.
Do not bore your stock sleeve to 88mm. You can purchase an 88mm sleeve from LA or Wiseco. Make sure you upgrade the timing chain to a 2002-2008 CRF450R/450X- 2006-2008TRX450R/450ER chain part # 14401-MEB-671. Replace the guides too.
ok ill guess ill buy a couple of jets and the cylinder i bought presleeved idk if it is a stock sleeve or not what would be the difference ive spent almost $500 so far tring to get everything to make my quad a 426 and i allready have a 450r timing chain that happened when it got a stage 2 hotcam
If its a stock sleeve bored. (Which i would bet money it is) the sleeve at the bottom would be very thin. I mean sketchy thin. If its a sleeved jug it will be roughly a 1/4 inch thick maybe alittle more.
I always use jetRus. And yeah you run the risk of the sleeve cracking being that thin. Do alot of people do it? Yes. Would i ever suggest anyone to? No.
Discussion Starter · #12 ·
ok well i just took the head and cylinder and studs to the machince shop its gonna be $275 for gt thunder studs installed true up the mating surface on the head and port and polish and and a valve job and clean up the head and i bought jets from 180-195 just to be sure and 45-48 just to be sure dose that sound like a good price for all of that machine work ( theyve been in buisness for 60 years and have amazing reviews even from a friend)
I paid 120 for the gt thunder studs installed at snure interlocking. And my family friend owns a machine shop that did the bore, hone, and decking for 40 bucks. Valve work and flow beanching head with p&p was another 40 bucks. And that was installing my +1mm valves, high rev springs, titanium retainers, new valve seals.
We wont talk about how much it cost to fly cut the piston though. That hurt alot lol
The only reason you would need a dpr9z plug is if your riding at wide open throttle for a long period of time. Or if tuning it makes it necessary. Reading the plug will tell you if it needs to be a colder or hotter plug.
1 - 20 of 23 Posts
