Who should be May 2019 Honda ATV of the Month?
  • SlammedRanger
    Votes: 5 83.3%
  • FTMike
    Votes: 1 16.7%
Status
Not open for further replies.
1 - 1 of 1 Posts
· Super Moderator
Let the voting begin for the May 2019 Honda ATV of the Month! We will leave the poll open until the end of the month and then announce the winner. We got some really good pics this month, thanks to everyone that participated and GOOD LUCK!!
SlammedRanger
07 gusseted frame(done by mudmotorsports)
05 custom mudmotorsports subframe
+2 alba a-arms(custom needle bearing upgrade)
+1 lonestar swingarm and double row carrier
Pivot works bearings on everything
T.M. designworks chain slider and rear slide and glide kit
Elka legacy stage 3 long travel front and rear
Gt thunder xc link
Rpm dominator II axle
Blingstars brake rotor guard
Atv specialties double sprocket guard
RK x-ring chain renthal sprockets 13/38
Moose sprocket guard
05 trx450r spindles and brake calipers
Galfer brake lines
HMF full pipe, xc front bumper and xc low 450r grab bar
Houser pro bounce nerf bars
Kasedplates composite skid plate
Dwt rokout front rims with maxxis razr 2 tires
Alba racing beadlocks rear with maxxis razr xc tires
Mud motorsports custom hump seat cover
CCP steering stabilizer
Uni filter with ehs power lid
07 yfz450r FCR 39mm carb. R&D powerbowl 2 and flex fuel screw
^^^alot more custom work in this carb^^^
Wiseco 11:1 87mm piston fly cut for valve clearance
+1mm kibblewhite intake and exhaust
Titanium retainers and high rev spring kit
Stage 2 magnum cam
Crf450 timing chain
Gt thunder hd studs
Lightened flywheel
EBC dirt racer clutch 20% stiffer springs
4 inch spal fan on oil cooler
Air shrouds
Oil temp dip stick
Cometic gaskets
Motion pro cables
MSR ez pull clutch lever
Moose ez push throttle housing
Acerbis rally hand guards
Fasst Flexx 12° bars
Oury pillow grips
Mod quad dash and riser
Trx450r vented hood
Cycle1 hmf graphics kit
Race cut wire harness
Pro armor teather switch
Custom ram air intake setup
FTMike
2014 Honda 420 4x4 ES
31" OG Outlaws
2" lift
Snorkeled
Warn Winch
Rigid Lighting
35% Gear Reduction
1 - 1 of 1 Posts
Status
