Let the voting begin for the March 2018 Honda ATV of the Month! We will leave the poll open until the end of the month and then announce the winner. We got some really good pics this month, thanks to everyone that participated and GOOD LUCK!!
SlammedRanger
07 416ex
Custom hmf graphics kit
87mm wiseco piston(flycut for valve clearance)
+1mm kibblewhite titanium intake and exhaust valves
Kibble white high rev springs and titanium retainers
Magnum stage2 cam
Cometic gaskets
Gt thunder hd head studs
Crf 450 timing chain
Hmf full system
FCR 39mm carb(Tokyo mods spring, R&D power bowl and flex jet)
Custom intake with uni filter and power lid
EBC drc clutch kit(20% stiffer springs)
4 inch spal fan on oil cooler
Cfm air shrouds
Hmf defender xc front bumper and xc low rear grab bar
Houser pro bounce nerf bars
Acerbis rally hand guards
Fasst Flexx 12° low handle bars
Mod quad dash and riser
CCP steering stabilizer
Galfer braided brake lines
Moose ez pull throttle housing
Msr ez pull clutch lever
Motion pro cables
Maier 450r hood
Pro armor kill switch
Elka stage 3 long travel front and rear shocks(gt thunder xc link)
Alba +2 gull wing a-arms(custom needle bearing upgrade)
HD tierods,ball joints, and tierod ends
Lonestar axle +2
Stock gearing with RK x-ring chain and renthal sprockets
Mud motorsports custom hump seat
Mud motorsports custom subframe
Blingstars axle nut and brake rotor skid plate
CNC machine wave rotors all the way around
Prm full under body skid plate.
2 full sets of tires and rims
XC- maxxis razr xc 20x10x9 rear and maxxis razr 2 21x7x10 front
On alba bead lock rear and dwt rok-out front
MX- maxxis razr mx 18x10x8 rear and maxxis razr cross 20x10x7 front
On dwt champion in a box rims
djones118
_Wilson_
1999 fourtrax 300 fwd
Itp at mud lites
honda speedo kit
Honda cooling fan kit
424 switch out
CMP front bumper (soon)
Lift kit (soon)
honda handle bar gaurd,
ram 500,000 CP halogen spot light
uni air filter
Bel ray foam oil
Dimple magnetic oil plug
Honda front basket
Custom front drive shaft gaurd, thx to FF
Second honda brake light / brake banjo switch
55 watt halogen head bulbs
bright aluminum plasti-dipped rims
Honda Head light brush gaurds
