It would be a good idea. I need to measure mine to see if it's 18 mm...Whattaya think cajunman wanna do a thread on it?
looks good to me ?, I've used the ones that you have to seal in with sealant, but this one looks like it will do just fine. measure your sight glass hole, and see if it's 18mm ?.you have two options, one, which is very high dollar !, replace the whole master cylinder. two, replace the sight glass ?. then can be done a couple ways, either jb welding a dime in there ?, or using a replacement sight glass kit from ebay. you have to search for motorcycle sight glass kits for Honda, but they are all the same when it comes to sight glasses on master cylinders for brakes and clutches.
Is this one a good replacement?
Brake Master Cylinder Sight Glass for Honda Yamaha Suzuki Kawasaki Motorcycle | eBay
Are they hard to replace?
I found this instructional video. Hopefully, the one I'm looking at removes and installs similarly....Is it just a snap out with a screwdriver and then press in the new one Shadetree?
I use a digital mic I bought from harbor freight , about 10 bucks ?. it measure in inches and mmlooks good to me ?, I've used the ones that you have to seal in with sealant, but this one looks like it will do just fine. measure your sight glass hole, and see if it's 18mm ?.Is this one a good replacement?
I know this is a stupid question LOL but since I'm ignorant about such things, including math LOL, what's the best way to measure them? All I have is a measure tape, and measuring the window across, I know 18mm is way too large. I want to get a correct measurement before I purchase a new one.
as I said earlier, most all Honda master cylinders are 18mm.I used a vernier caliper to measure the inside diameter of the silver ring--and came up with 18 mm--this caliper shows measurements in cm
So I should be 95% safe getting that one in the Ebay link?as I said earlier, most all Honda master cylinders are 18mm.I used a vernier caliper to measure the inside diameter of the silver ring--and came up with 18 mm--this caliper shows measurements in cm
yep, should fit, read their ebay feedback score before you buy ?!, this says a lot about their productsSo I should be 95% safe getting that one in the Ebay link?as I said earlier, most all Honda master cylinders are 18mm.I used a vernier caliper to measure the inside diameter of the silver ring--and came up with 18 mm--this caliper shows measurements in cm
I've done the Allen screw conversion on anything with a cap/lid on my 300 that originally had those god-awful Phillips screws. Brake reservoir, vacuum plunger cap on the carb (to easily access the fuel needle without removing the carb from the bike), carb bowl, etc.there is also a allen screw set you can buy to use in place of those rusted out, hard to remove screws !, I need to buy me a few sets, and use them on all my atvs, I got them on my motorcycle master cylinders for the clutch and brakes, they make it soooo much easier to remove the covers on them.
I agree, those pesky screws are a pain to remove if they have never been removed for some time ?, I always have to use a drift punch and hammer to tap them out, what a pain I tell ya !..lol.I've done the Allen screw conversion on anything with a cap/lid on my 300 that originally had those god-awful Phillips screws. Brake reservoir, vacuum plunger cap on the carb (to easily access the fuel needle without removing the carb from the bike), carb bowl, etc.there is also a allen screw set you can buy to use in place of those rusted out, hard to remove screws !, I need to buy me a few sets, and use them on all my atvs, I got them on my motorcycle master cylinders for the clutch and brakes, they make it soooo much easier to remove the covers on them.
It's well worth a few bucks to replace them before they strip out.
Will doyep, should fit, read their ebay feedback score before you buy ?!, this says a lot about their productsSo I should be 95% safe getting that one in the Ebay link?as I said earlier, most all Honda master cylinders are 18mm..
the video shows him punching a starter hole out from the inside, but you can do it either way, just don't damage the metal ring ? ( not that it does anything important )..lol.Will doyep, should fit, read their ebay feedback score before you buy ?!, this says a lot about their productsSo I should be 95% safe getting that one in the Ebay link?.
So I remove the old one from punching it out from the inside, like that video shows?
been there, done that, they break off down in the master cylinder, lol. out of all the parts to work on ?, those screws are the worst !..lol.I have had to drill out many of those screws in the master cylinder cap , seems they usually are stuck in the cap as once you drill the beveled head away and get the cap out the way you can grab whats left of the screw with a needle nose vise grip and they come right out
