Make your own test adapters for testing sensors and other components on ATV’s.
First your will need a Female & Male harness connector, they don’t have to match. If you don’t have any — ask one of the ATV repair shop for old ones that they would thrown out.
You will need a Bobby Pin or Precision Screwdrivers set — I find the Bobby Pin works for me.
Bobby Pin is to remove the Female & Male pins from the connectors.
Solder a Female end to a Male end to make a jumper — make up 3 or 4 jumpers — leave the heat shrink so you can slide it to place your meter on it.
The adapter with the 3 Alligator connector I made that to test the Bank Angle sensor -- got carried away, all you need is 3 F & M jumper pins.
When testing a sensor unplug the sensor -- plug the required jumpers into the sensor and then back to the harness do your test.
Discussion Starter · #2 · (Edited)
Also some have been asking about Peak Voltage Adapter -- here build your own
The Push button is used to discharge the capacitor in the tester after use.
Your digital multlmeler should have a impedance of 10 Meg ohms/DCV minimum.
Good work Mel, that’s very useful indeed.
i've used a bobby-pin before[hairpin], had to file off burrs on some. not every thing is of quality, even in the old days.:smile what works is what works. i used hairpin to fit in the female slot, and have a clamp thingy, i can use the probe with, with a wire connector. i want to find alligator clip that works this way..
You cant always find what you want,
So make what you need,,
"Rolling Stones"
stickie
good thread.. any chance this sticky could also be in a different spot. perhaps, repair and maintenance, or another.
good mechanics, learn to adapt. maybe some others have shortcuts as well. :smile
