My steering progressively got worse and then got a lot of slop and it and when I looked down the lower part of the steering shaft would move about a quarter of an inch when I turned. I ordered a new bearing and some other pieces to replace the lower area and now I have things torn apart but when I look at the area where the new bearing is suppose to go it looks like I need to put the bearing in from the bottom but the bearing will only fit from the top. Do I need to try to hammer out all the stuff in here or just tried to push things in from the top? Any advice helps, thanks. (And pictured is looking up)
