Hey guys I’ve got a 08 Honda rancher 420 and the starter won’t spin when you push the button. Everything’s clean it starts when you bypass the solenoid with a screwdriver. With the solenoid wire disconnected from the starter I measure 5 volts to ground at the plug and moving up to the line side of the push button on handlebar it measures 5 volts. I’ve traced this wire back to the ECM and tested it and its output measures 5 volts or really close? Any help would be GREAT!
Does anything happen at all when you hit the start button? Does the solenoid click? Could check the resistance of the start switch. I'm not sure if the 5 volts at the ECM is anything to worry about. A manual would be helpful.
Hi: Go to the fuse box and check fuses main 30 amp fuse and Ign. 10 amp fuse -- here is how to do it -- turn key on -- leave the fuses in place -- look for a little gray dot on the top of the fuse -- test each gray dot to ground -- what did you find?
