So I have this 2004 Honda Rancher TRX 400 FA which has performance issues at low rpm, I picked up a carb kit for it, thinking something might have gotten plugged up as it sat awhile, and a compression tester as well as I had noticed air coming out of the oil dipstick w/ the engine running.
I measured 73PSI on an cold engine. I dumped a bit of seafoam down the spark plug hole to maybe get the rings unseized as it is a 14 year old machine and only has 300 hours.
I will also try adjusting the valves tomorrow. I would like to get around a top end rebuild if possible because a seal kit (not including valves) runs me around 320$CAD at my Honda dealer.
Any suggestions what I might try??
Thank you!!
Thank you!!
