1 - 12 of 12 Posts
hello,,ok, so i snrkled my foreman,,i've seen and did what i've read here..2'' out of airbox to 1.5--i'm only going to tank cover..It comes up btween seat and gas cap.. Top speed b4=62;'';';' top speed after=57..what's the problem here,,noticed a little spudder at top speed
You might not be able to snorkel yours without rejetting, because Fastas has a 300 and if you have a Foreman, then your engine is bigger. A bigger engine is probably going to need a little more air flow. I don't know this for sure, but it's just a thought. Do you know anyone with a Foreman that has snorkeled theirs without rejetting?
I have snorkeled my nephews and used the spa hose with no problems. But there is no 90 deg. turns just smooth curves. I would assume the fluid dynamics of the 90.deg. turn has an air "flow" issue going to the carb. if you can take the 90 out and use smooth turns instead it will most likley work.
1 - 12 of 12 Posts
