2000 Honda Foreman 450 ES
A friend I don't see very often pulled up my driveway with this bike on his trailer a few weeks ago. Said it doesn't charge the battery anymore... "I think the stator might have burned out a couple years ago, think you can fix it?" "Sure" I said, as long as you aren't in any hurry to get it back right away? No problem he says... "It hasn't been running at all for about a year now. I'd like to have an ATV again, but the new ones are so expensive... maybe you can fix this one up? Keep it as long as you like, it ain't doin' me any good anymore."
I responded, "I'll get back in touch with ya in a couple weeks after I find time to check it out. Lets drop it back here..."
The stator tested good. The battery, once the mud was rubbed off of it, looks to me like the original OEM Yuasa. The battery voltage measured just 0.265 volts and one cell is so dead shorted it pegs my battery charger. The regulator/rectifier is probably junk and the connector terminals were found green with corrosion inside. The Solenoid sticks as soon as the starter button is pushed. The starter motor runs, but does not crank the motor over. When I asked him about that, he said it has been that way for years... use the recoil starter to crank it instead.
Uhh... no... I had already spent an hour appraising the bike. It is junk. Its done. Used up. I was thinking to myself it might be worth 100 bucks for parts to someone, but it wasn't worth anything to me. It might be far too late to save it...?
So I asked him how much he was willing to spend on it? I mentioned that it might be made a roller again for about $1400 in parts and supplies... give or take... depends on what else I find wrong with it that I cannot see yet? Its gotta be torn down 1st I told him... there'll be more that needs fixing. He said go for it then. "I'll drop some money off".
So, $1400 (+-) is the opening ante. That figure will definitely be increased a bit as eyeballs get inside it.
The goal is to restore this bike to as close to perfect mechanical/electrical/functional conditions as is possible. AND to carry it out the other end of this project looking as close as possible in its appearance, as a brand new bike....!
All within a very constrained, very challenging budget.
This Foreman has worked very hard and has never been loved, as you are all about to see. If this game can be won, it might find much better care... for a while anyway.
My 1st thought was that I am about to put lipstick on a pig!
