I have a 2007 Honda Rancher TRX 4x4. I have started having problems with the lights here recently. Started out only the left light was out. then one night the right side high beam just went out. the only thing I have left is the low beam on the right side. I replaced the bulbs and this doesn't help. does anyone know of anything I need to look at? is there any fuses?
Sounds like a fuse or relay check owners manual for fuse location, probably around the battery.
I agree with 69quadracer. But you might also want to check the wires the lighting systems on these quads weren't the most enviroment friendly corrosion,dirt mud could also be the culprit. Check your grounds usually the green wires are grounds on our quads.
Thank you for your help. I will have to try that this evening when I get home. That will give me a good starting place. Wasn't really looking forward to trying to trace it back through the wiring harness.
