Surely, this has been discussed before but I can't seem to find it.
I have the led pods which I'll be using to replace the factory headlights on my 99 trx300. Since only one circuit will be used (low beam) I'd like to mount a light bar and run it off the high beam circuit. I'll be installing relays and running a separate power wire off the battery (fused, of course). Here's where it gets tricky...I want the high beam switch position to operate both the pods and the light bar together. If I simply install them as stated above, power would backfeed to the light bar when the low-beam switch is on. To fix that issue, I think all I need to do is add a diode on the low-beam side to cut power to the light bar.
Has anyone done it this way...or have a better solution? If I'm on the right track, I need help finding a diode that will work.
Thanks!
Thanks!
