1 - 1 of 1 Posts
Supporting Vendor
Shop MotoSport.com for everything from OEM Parts to Lift Kits for ATVs!!!
Quadboss Lift Kit
Price: $40.77 - $289.99
Product Description:
-Improves ground clearance.
-Laser cut and powder-coated for durability.
-Easy to install with no special tools.
-Lifts unit 1 to 1-1/2''.
-May accelerate drive line failure.
-Stainless steel.
-Kit contents will vary by model.
High Lifter Lift Kit
Price: $74.99 - $216.99
-High Lifter designed a lift kit that is designed to lift your ATV to improve performance and handling from a company that is known and trusted in the ATV industry.
-The High Lifter lift kit is designed and constructed to increase ground clearance by 2'' by itself and with larger tires up to 5'' of lift is possible. -Designed for maximum performance and improved handling, the High Lifter lift kit lowers the front A-arms similar to the design of lift kits designed for independent front suspension 4WD trucks.
-High Lifter Designed the lift kit to increase the space between your ATV tires and fenders to allow larger tires to be mounted.
-The High Lifter lift kit is easy to install and rear end lift rotates the rear axle to raise the ATV.
1 - 1 of 1 Posts
