We all know that if you get anything other than OEM wheel bearings they come with some garbage in them that's supposed to pass for grease. Most of us will tell you to pack them with fresh grease before you install them.
That said.....
I've seen some people say that if you put too much grease in a wheel bearing that it will cause the ball bearings to slide instead of roll, which leads to flat spots and premature bearing wear.
I actually got one of these a couple of years ago. I liked the fact that it greases from the inside out, which means it pushes the old grease out of the bearing.
I've got these 420 knuckles cleaned up and have a set of Pivot Works bearings to go in, and I'm trying to decide if I should pump them full of Mobil 1 syn red grease or leave the stuff in there that came in them
Pivot Works actually has a "lifetime warranty", which in reality means they'll replace them once after they wear out. I haven't worn out a set yet but this is only then 2nd machine I'll be using them in.
Thoughts?
That said.....
Thoughts?
