Recently purchased a used 2014 Honda Rancher 420 FM1. While replacing the left rear brake/reverse assist cable I noticed that the former owner must have replaced the bracket on the handlebar. It is brownish in color rather than black and is canted slightly forward. Also, the bracket is broken on the bottom and this is causing the guides for the cables to not be aligned properly. I am trying to remove the bracket to replace it. It is held in place with two screws, lower and upper. The screws are impossible to remove. I have the correct bits. It appears the bracket didn't quite meet in the middle so someone just screwed it down as tight as possible. I am open to any suggestions.
