I read when doing a search on this forum that the stock bulb is 45w.If this correct the 30w ones would work with the wire and switch.Now if anyone help me choose spot or flood.Were you happy with the floods.I fitted 18w floods in place of the stock headlamps and added a 180/200w spot light bar above on the carrier. 18w I thought was an equal match with stock bulbs so 30’s would be above stock bulb average.
I would stick with 18w or 30w though, not sure how much power the wiring harness and switch can take can take, my light bar is wired through a relay.
Good point ,but there won't be any oncoming riders.I use the ATV for hunting only.The lights I am looking at are 24w each.Would they be bright enough?Idk about the lights but I used the auxbeam harness–works well.
I haven’t seen a good directional LED setup yet. They are not mounted in a deep enough reflector to be directional so they really blind oncoming riders
I think anything will be a vast improvement over the stock halogen bulbs. I’m going to install H6M LED bulbs in the OEM housings, then add a 9” bar on the handlebars, above the dash, like the attached pic. This one has the flush mounts too.Good point ,but there won't be any oncoming riders.I use the ATV for hunting only.The lights I am looking at are 24w each.Would they be bright enough?
I did something similar to my 350D. I also replaced the stock H4 headlight with an LED bulb. Nice tires ?
