1 - 2 of 2 Posts
I am trying to replace my old halogen headlights with some led pod lights. I am trying to use the wires from the old headlights which you should be able to do but it is not working. I am not getting any power at those wires. The headlight switch works as the tail light comes on when I turn the switch on, Any suggestions as to why there is no power going to the headlight wires? Maybe a fuse or relay I missed? 1999 Honda Fourtrax 300 4x4
I assume the headlights did not work at all before you took them out. Verify that your replacement LED lights work first. Then get a copy of the service manual and look at the wiring diagram... no voltage at the headlight plug could be as simple as a blown fuse or a bad plug connection somewhere in the harness. The FSM for your bike can be found HERE.
Welcome to the forums!
1 - 2 of 2 Posts
