1 - 2 of 2 Posts
I am looking at buying an 06 Honda 450er, the only modification it has is an factory installed HRC kit. I noticed it leaks from the valve cover gasket and I was wondering what could be wrong? And what causes it to leak from that gasket. Also if the gasket was replaced would it go out again?
It uses a rubber gasket that normally doesn't good bad. It might just need the bolts snugged down a little bit more.
Rob
1 - 2 of 2 Posts
