I have a Honda Fourtrax 250 1986 and it was filled with too much oil and now fuel leaks at the bottom of the carb through the vent line, it used to run for a while and then stop, we had someone come fix it, but they weren't able to finish it, he was able to rebuild the carb, but it still had to much oil that we didn't know about, and it wouldn't idle and would only run if you constantly pressed the throttle, I took out the extra oil and I also found out that the screw at the bottom of the carb was closed so I opened it and it ran really good, but gas leaked out in a pretty steady stream, so I moved the hose so its above the carb and now it seems to run good and no fuel comes out, but I'm not sure if this would be bad for it or not, can someone tell me if this is right, and if not what I can do to fix it, I can post pics if needed
