Kolpin boxes/fuel packs for my Rancher 400 AT
21152 Views 22 Replies 8 Participants Last post by  melsman
5
My wife and I are getting ready for a three day trip this summer through Utah’s Paiute, Fremont, and Pansaugant trails. In prepping to do so, I decided to outfit my Rancher with front and rear boxes, fuel packs, bags, and GPS. She and her family all ride sport quads – I’m the only utility quad, so I will be the mule.
I chose the new Kolpin rear (93201) and front (93101) trail boxes mostly because they looked good and were priced right. They seemed to offer good storage area without being too ugly. And I wasn’t disappointed. The rear box has a 10”x 29” mouth and has a depth of 10” (the “pockets” on both sides add a couple of extra inches forward), and handles the stuff I take on our one-day rides really well. The lid seals nicely and keeps out dirt and moisture. I purchased the top rack (93202) for the rear box with the belief that I’ll need the extra storage on our longer trips. The lock feature on both boxes is also nice. As for the front box, the mouth is 6”x 26”, and is 5” inches deep. The box interior adds another 4 inches forward once you get through the mouth. However, I do have a few “improvements” to offer.
First, the bottom of the boxes are not reinforced – which is not an issue with the shorter front box, but more of a concern for the taller, rear box. I didn’t like the stock u-bolt mounting system on the rear box because, IMHO, is just didn’t give enough stability and solid mounting. So, I fabricated larger 2x4 steel plates from 16 gauge metal, and also added slightly larger rubber pads to go underneath the plates to keep them from cutting into the plastic bottom. (I cut smaller pads for the stock plates on the front box. The stock mount plates work just fine on the smaller front box.) I didn’t use the sealing washers the manufacturer supplied on either box – I think my system of larger plates and flush rubber pads seals the box just fine and distributes the stress loads much better.
But even adding large plates wasn’t enough to keep the rear box from rocking forward slightly. So, I cut a portion off of a u-bolt to make a threaded “J”, and hooked it underneath the rear rack bumper bar, and tied it into the interior lip. I also replaced all of the standard nut/lockwashers with nylock nuts, and cut half of the threaded portion off of each u-bolt. The manufacturer supplies rubber caps to cover the part of the bolt that is sticking up after installation – I chose to cut it off. It makes for a cleaner installation without leaving metal rods sticking up in the bottom of the box. I also added a closed-cell foam floor.
As for the rack, it was of ok quality – even though the welds looked like they were done by a beginning welding class. And the center support cross tube has open ends – perfect for wasp nest building. So, a couple of 7/16” plugs from the hardware store finished it off properly.
I didn’t use the stick-on reflectors on the boxes. I didn’t see a need for them, so I didn’t use them, which was good since the rear box came with two left-side reflectors, instead of one left and one right. (They are not interchangeable.) Again, not a big deal to me – just a minor QA issue at Kolpin.
The Kolpin fuel packs (89185) are nice, heavy-duty plastic cans that hold 1.5 gallons when filled to the bottom of the spout neck. I ordered two packs with the round wall mount, rather than the rack mount. I was going to try and figure out a way to build a metal mount to attach the cans to the sides of the rear box. But after an hour of trying different options, it dawned on me that the only option was to use the rack-mount system on the sides of the rear rack. So, I ended up using my wall mounts and fabricating rack mounts out of 3/16” steel. The rack materials cost me about $20. Even though I saved about $20 by building them myself using the wall mounts, if I did it again, I would just skip the extra work and buy the Kolpin rack mounts straight out.
The CARB-compliant pour spouts on the fuel packs are interesting… And they worked fairly well and did not leak. However, I put a small amount of grease on the neck seal and the valve o-ring, and cleaned up the lip of the fuel pack, since there was a little flash left from the molding process. I highly recommend taking the time to do this to get a good, solid seal.
Overall, I’m very pleased with the Kolpin equipment. I’ve been using the rear box now on a couple of our rides and have tested the front box and fuel packs and mounts on a local test loop down in the creek bed. So far, everything is working very well. I am looking forward to using it all on our trip this summer.
Melsman
See less See more
1 - 20 of 23 Posts
Nice work..Looks great...Now see if the combined boxes will hold enough women stuff for a several day outing .. ;)
4
... couple more photos
Thought I'd throw up a few more photos of the finished product.
Melsman
See less See more
Looks like the rear has squatted a little with the box,rack,cans n all ...
@DeeperITB - Ha! Yeah... and if she makes one more crack about me being the 'geek' in the bunch, she's going to be carrying all of her stuff in a pack on her back...
Melsman
Better get her a good backpack,or a 6 pack rack... ;)
... or one of those helmets with the cupholders on the side. :laugh:
On the 'squat' issue, the two fuel packs (with mounts) weigh 15 lbs each when full, and the rear box with my equipment bag, water and full cooler, weighs 40 lbs. So, this adds 70 lbs to the rear. However, I do have a bit of concern because this 70 lbs is centered high and to the rear, so I'm going to need to be careful on steep inclines.
And I've already almost flipped this thing once (with the 40 lbs rear box on it).
I guess I need to put some weight in the front box.
Melsman
Looks good! Definitely got the pack mule look going on. :laugh: I need to do something like this with my prairie. Found out yesterday its a bit of a gas hog. Burned 1.5 gallons in 3 hours, vs. my honda that only sipped about 3/4... I need to figure out how to mount some extra fuel cans, that won't get bashed in if I were to flip it over side ways (sooner or later its going to happen, don't wanna go boom when it does...)
I like that, but in my style of riding, I would lose that rear box and cans. I have yet to see to see how far mine will go on a full tank of fuel. Same bike as yours.
Melsman, I rode the Paiute trails 2 summers ago and it was a lot of fun and nice riding. It also offers a lot of varied terrain. Are you going to ride out of Marysvale? If so, consider staying at Liz and Charlies.
2
@ Kentco - We have property in Beaver, which will be our start point. We'll head over the mountain to Circleville, fuel up, and head south on the Fremont trail to the Bryce Canyon area. Looking forward to it... I love the Bryce area. One of my favorite places on earth.
@ David Anderson - Actually, that's the reason I got the box. I kept losing my stuff off of the back of my wheeler. (See photos) I've put the rear box through some pretty tough jolts, including minor jumps. So far, it's held up pretty well. But then, I've got that sucker anchored pretty well.
@ Dan G - My Rancher 400 AT went through about 1.75 gallons in 32 miles of hard riding the other day. I'm still working on my initial fuel consumption calculation run, though. (I screwed it up the first two times I did it.) I think I'll be able to get about 60 miles on a tank. I shouldn't need extra fuel, but we're going to have 5 bikes going, so I'll carry the 'Oops' fuel.
Melsman
See less See more
@ Dan G - One other thing...
Not that I'm a Kolpin salesman, but - they have a larger rear box called the "Outfitter" that comes with the top rack and has two flat pads on the rear to mount two Fuel Packs. Kind of a nice design - lots of space and convenient fuel can mounting. (see photo) Would probably fit your Prairie well... with a shoe horn. Or at least give you the ability to do wheelies easily...
Melsman
See less See more
Melsman, Have a great time. I didn't know that there was much riding, or territory open to ATV's around Bryce. I'd love to go to that area!
Kent
@ Kentco - Yes; even though there's no riding inside the park itself, there are a lot of trails around the canyon. Especially on the western side (the Pansaugant Plain). The red canyons northwest of Bryce have some very scenic trails that are open to ATV's, and the hotels in the area allow drive-ups on ATV's.
Melsman
Looks really good with the packs and equipment on there.
Sounds like a good trip and the rancher looks good with all of the boxes on it.You should be able to carry enough stuff for everyone.
lol, thanks for the box idea, better wheelies are always a plus. :D I like the look of the box... I'll have to price them out. Definitely would be a lot lighter than the metal alternative I was thinking of making... Sounds like you guys are going to have a blast on the next trip.
Melsman: I appreciate the information and will definately make note of it. Bryce is an area that I would love to see. My wife is also a photographer, so I know that there would be a LOT of great photo ops for her there.
Thanks so much!
Kent
2
Howdy Everyone,
Thought I'd throw up some pics of the boxes in action on our trip through Bryce area/Casto Canyon. The talcum powder-like dirt coats everything, including the back of the Rancher. Good thing the boxes seal well.
Melsman
See less See more
Looks like you got some cleaning to do. lol glad you had a safe trip
1 - 20 of 23 Posts
