either you got the wrong ball joint ?..or your knuckle is too worn..do not ride it like that. make sure you got the right ball joint..and if so..replace the knuckle.When installing a lower ball joint in the knuckle I found that it fits in the whole to loose barely needing to press it in. What should I do because I am afraid that it will come apart while riding?
