‘00 TRX400EX
I have a 2000 trx400ex; the carb needle seems to need adjusting but, there’s only one position on the needle sooo.. any thoughts/suggestions?
Bogging down, coming downhill and while level but, not going uphill.
Help 😭
please and thank you.
2020 520 rubicon foot shift
Check the float height, if its too low it will run better when the atv is tilted ahead or back.
You could also have a plugged up fuel petcock, they do funny things like this too. As a quick test you can run it on reserve, if its better it's the petcock.
I have the same problem when I'm running out of gas. Flip it to reserve and all is well.😉
