My starter switch wouldn’t switch from run to off so i took it apart. Besides a bunch of web worm carcasses in the switch housing, the kill switch musta been damaged during the PO’s rollover.
It is a little plastic box with a protective cover. Inside is the switch mechanism–it has a spring and a metal ball that contacts a detent. Very similar to the safety switch on a Mossberg 500 shotgun but slightly larger so DONT LOSE IT lols
I cleaned and lubed the switch and in process broke the wires.
Resoldered the contacts and rewrapped the harness
Kill switch stuck
What ATV, what year, Amy previous symptoms, is this ATV new to you?
Help us to help you!!
