Put a new carb on my atv still it back fire's I sure could us some help getting it started and I put a new plug in it still nothing
Sent from my N9518 using Tapatalk
You computer (CDI) may be bad. The CDI box could have moisture in it. Although, this box is a sealed unit. After time the box may develop hair line cracks in the seams where it joins together.Put a new carb on my atv still it back fire's I sure could us some help getting it started and I put a new plug in it still nothing
Thanks I'll get one and see if it worksYou computer (CDI) may be bad. The CDI box could have moisture in it. Although, this box is a sealed unit. After time the box may develop hair line cracks in the seams where it joins together.Put a new carb on my atv still it back fire's I sure could us some help getting it started and I put a new plug in it still nothing
Sent from my SM-G935V using Tapatalk
If you can rule out bad gas. I would try the CDI. Amazon may have one for your ride. I just bought one from Amazon for a Yamaha Rhino, fixed my back fire issue.Thanks I'll get one and see if it worksYou computer (CDI) may be bad. The CDI box could have moisture in it. Although, this box is a sealed unit. After time the box may develop hair line cracks in the seams where it joins together.Put a new carb on my atv still it back fire's I sure could us some help getting it started and I put a new plug in it still nothing
Just put new gas in it eBay has one cheaper than AmazonIf you can rule out bad gas. I would try the CDI. Amazon may have one for your ride. I just bought one from Amazon for a Yamaha Rhino, fixed my back fire issue.Thanks I'll get one and see if it worksYou computer (CDI) may be bad. The CDI box could have moisture in it. Although, this box is a sealed unit. After time the box may develop hair line cracks in the seams where it joins together.
Just ordered oneJust put new gas in it eBay has one cheaper than AmazonIf you can rule out bad gas. I would try the CDI. Amazon may have one for your ride. I just bought one from Amazon for a Yamaha Rhino, fixed my back fire issue.Thanks I'll get one and see if it works
No sure haven'tHave you checked your valves? Timing? Adjusted the air/fuel mixture?
I’d check the basics before I started throwing parts at it..
If you put a hire octane fuel would that burn the valve up fasterHave you checked your valves? Timing? Adjusted the air/fuel mixture?
Yea my brother in law has twoThose bikes are tough. A buddy of mine has one and that thing is like a tank. Always runs good too.
I concur.Have you checked your valves? Timing? Adjusted the air/fuel mixture?
