Hi all ! I just purchased a Green 1995 300 Fourtrax 4x4 and the rear end is in some really bad shape. I pulled it apart and the brake parts are all completely worn out as the bearing in the brake back plate was totally gone and the brake pads lost there mounting post as it was broke too. With the bearing destroyed in the brake back plate it even lightly grooved the axle surface that the bearing rides on. I haven’t opened the differential yet but it seems like it might be rebuildable. So I’m into all new bearings ,no big deal, axle, brake back cover ,brake drum and cover. My question is what is the experience in buying some of the aftermarket parts that are out there? Am I better off finding a used good axle ,brake back plate and brake drum. And what is good source of bearings you guys use? Your input is valued ! :nerd
