Hey Guys,
I am new here and of course, I joined because I have a problem. First, let me tell you a little about myself and then my atv. I am an auto mechanic by trade and have been for about twenty-seven years. I know some about atvs and understand there terminology very well but I'm not technically trained or know them in detail. That is why I am here. I hope to be able give advice as well as receive from this sight. I have a '07 Honda Rincon camo, bought it new in '06 and except for 27" tires it is still all stock. I believe that I have about 150 hrs on it now but the meter is off. I had to replace the instrument head, only because someone’s face went into it. I never had any problems, until now. I have changed all the fluids more than necessary, only because I can, being a auto mech I get fluids very cheep and do all the work myself. I use 10w40 non syn non energy conserving oil and premium limited slip 75w90 in the diffs. This is what my dealer said to use so I stuck with it.
Now with the problems that I have. The three most important are, first I have a loud grinding noise in the engine/trans, only when applying the rear brakes, hand or foot, in 4x4 or not, and this does not happen when applying the front. However, it is definitely not in the brakes. I have taken them completely apart cleaned and lubed the slides and still have about 90% pad life left. I have read that the rear rotor comes apart at the rivets so I welded the rivets, inner hub, and rotor together so that they do not move independently. Noise still there. Second, another noise is on the left side of eng/trans sounds like metallic rattle or med. pitch whine. It goes away when I shift into gear but will reappear with light throttle when cruising at any speed, not accelerating and not decelerating. Third, I believe that the cam chain is loose. I also have alot of tapping noises. Valves have been adjusted properly. I am pretty sure I'm going to have to tear this thing apart, not a problem, but I'm not sure what to look for when I get it apart. Can anyone give some advice on what could cause these noises? And if they can be fixed without pulling the eng. I called the dealer and he said the rincon have a lot of noises. I am sure these are not normal.
Sorry for the long post I will try to be shorter in the future. Thanks
welcom to the fourms
Axle bearing perhaps or input shaft bearings in the gearbox... Welcome to the Forums
Welcome to the forums.
