I know basically everyone has a jetting thread, and i've tried searching but i cant seem to figure it out.
I put a aftermarket exhaust on my 04 250ex, and it was popping on decel.
I went to the local powersports shop and picked up a few different main jets as well as a larger pilot. (for the main, they didn't have any kiehn jets, but they had mikuni that fit, a 105, 110, 115, and 120) to solve the original issue, i figured i needed to up the main, so i tried the 105 to start and it was no good, so i jumped to the 115, and while i had the carb open swapped the stock pilot to a 45. I put everything back together and went to start it up and it fired right up. I took it for a little ride, and it was going good, slight hesitation at low throttle, but it was running and idling fine. I couldn't do too much on the throttle cuz it was late and people were sleeping though.
Today i went to test the higher throttle positions. It started fairly easy, and after a few i took it for a spin. The hesitation at low throttle became more obvious but the rest of throttle positions seemed good, no popping on decel. either. Then, all of a sudden, when going slow, it dies. Try to start it and it just cranks over. Pull the choke and it starts but wants to die when the throttle is released. Since then i have not been able to get it to stay running. It starts with the choke pulled but usually dies shortly after.
I tried playing with the pilot screw. I put it all the way in (lightly seated of course) and tried starting after each half turn out. I got it almost all the way out and the best i could get it starting with the choke pulled but it would die if off the throttle, and no start with choke down.
So, i'm stumped....
I'd like to add i'm totally new to carbs, but i've done a bit of reading.
Any input and help would be great. I dont really want to have to pay someone to do this after all i've done already.
Thanks in advanced.
So, i'm stumped....
Thanks in advanced.
