Jetting is refered to changing the main and slow jet sizes in the carb. You only need to do this if you alter the engine in anyway from it's stock performance. If you add an aftermarket exhaust, fitler or piston (higher compression) you need to compensate the air/fuel ratio by increasing the jet sizes. Or if you move to a location that is higher than 3000ft above sea level.
