ok well i just got my cam put in.its a torque monster now wish i could make the stance wider.anyway it backfires after letting off the throttle in N too.105 main(stock95) 42 slow(stock).airlids off.if i put a bigger slow jet it wont run.should i go up on the main or try going down i think it is and richen it on that thing that goes through top of carb?
If it's backfiring, it sounds like it's too lean. Might want to try going up on your main jet.
k thats what i was thinkin.stuff always happens on sundays
have you changed the needle setting? and when you upped the jets did you reset the air/fuel mixture screw?
changed slow jet to 45 and it ran.testing out tomorrow with new plug.
