1 - 2 of 2 Posts
Hi all,
I rejetted my 400 ex and thought i had it perfect. well it is running ok with a slight hesitation in the throttle in the beginning. it wants to stall out. Did i come out to much on the fuel screw or do i need to come out more to make it stop doing this. after i open it up it is fine its just when i first push the throttle. and after it warms up it is good but when it is cold it does this worse. plus if i just leave it sit it stalls out. Please help and let me know if i need to let the fuel screw out more or put it back in more?
Also I have a cracking noise coming from either my swingarm or suspension. I read before that i may need to lube the swingarm bolt? or could it be coming from the suspension?
Sounds like you might need to go up on your slow jet a little.
1 - 2 of 2 Posts
