I am told I have a 400ex carb. No idea how to tell considering it has no stamp that I can find on it.
The two Jets that were in the carb are a 135 Main and a 38 Secondary (or pilot).
Question 1:
How can I find out if the carb is a 400ex or not?
Question 2:
Do I have the proper jet sizes for using a 400ex carb on a 250x (Assuming I do have a 400ex carb)?
Thanks in advance!
Is there any mods done to the quad other than the 400 carb? if not then thats a bit much. go on ebay and look up 400ex carb and see if yours looks like that then look up one for a 250x. a 400 carb has a larg intake opening.
400EX carb
250X Carb
I have no clue if the engine was modded. I am beginning to think it was. Based on this .pdf which I just found:
http://www.powroll.com/PDF/2007 - NEW/JETTING/JETTING-HONDA-TRX250X-300EX.pdf
(And is quite handy I might add, maybe something to save!!)
It suggests that if you were to modify your engine you should start the primary jet 4 sizes larger than stock and pilot jet 1 size larger. That would be my setup exactly based on their lists!
Looks just like a picture of the 400ex carb on ebay.. can't find a good pic of 250x carb yet.. still working on it.
Nice find on that pdf!! I sticked it under the Honda ATV Schematics / Manual Help section.
Clearing up the muddle....
Well, I figure since I have asked the question and found the answers I should at least provide this information for those who might search this thread in the future.
I am working on a trx250x from 91'-92' era. To identify your carbouretor there is a stamp on the side of the throttle body just above the choke lever.
It reads "QB" with some serial #s below it. Mine says "02A A GK" and some japanese symbol at the end. Based on my Clymer manual and bike bandit, I have a 93' Honda 300EX carb. Fyi, A stock trx250x carb will start with "QB01B A".
If you do not have a manual, go to www.bikebandit.com search for the year and make/model of your atv, click on Fuel/Air and click on the image of the carb. At the bottom there is a parts list. Look for "Carb Assembly" and it will say "(QBXXXX)". This lets you identify a carb.
Proper jetting for the 300ex carb is 122 main and 38 pilot.
Hope this helps someone get the answers they need!
