Hi! Miss me yet? Ha! well, One 5mm kidney stone and the loss of my dog recently, I'm back at it again. Thankfully, I don't have about 1000000 questions this time around, but more pics and another video again! YAY!
I'll try to make this short. Done are most of the service section in my 400ex manual. Got the carb off and totally got her all cleaned up. Still have a crap idle, but now I know why...
The crankcase blowby return line that plugs into the air intake for the carb. When the quad is all warmed up and running, it's putting out constant air pressure in tune with the engine (a puffing of air) but with a hint of white smoke. This smoke is choking all my airflow on my quad and killing it! when I disconnect that breather from the intake, the quad runs like a DREAM! The smoke is barely visible only when it gets nice and warm. when it's cold, no smoke. I put a movie up on youtube that showed the smoke (it's hard to see, but a constant "puffing" with the motor idle) before youtube converted it into it's crappy format. Here is what is happening....
YouTube - Crankblowby.MOV
Now I have notice my oil looks off color. Possible water contamination I thought. I changed the oil in her, but only from the drain bolt. Not from the crank case (switched from a Castorl synthetic back to the HP4 synthetic and changed the filter). I was thinking I need to run a bunch of cheep synthetic through her and get all the contamination out, then drain and refill with HP4
Oil color -
I've read that if you have a gray color oil issues (possible water contamination), that you should run a bunch of oil through it to clean out all the old stuff. just keep filling and draining it from the filter on the side of the motor until it runs golden again. I was thinking that this contamination might be why I'm getting a lot of smoke from my crank blowby. The water mix with the oil making it thinner and easy to "burn" off inside the crank case.
Your thoughts?
Oil color -
Your thoughts?
