Its not a murder mystery. I have A 2002 400EX with a full HMF exhaust, K&N and stock lid. Ran perfect for the three years I had it, rarely had to choke it in cool weather. Finally it died suddenly, it had the original carb and I tore the accelerator pump rebuilding it so it was cheaper just to buy new. I found out when I took it apart the prev owner never jetted it like he said he did. Anyway new carbs come with the pilot screw sealed with a plug. So I pulled it out, had a dealer use the special tool to remove the new "D" topped pilot screw and I replaced it with the one in the HMF kit (42) at the same adjustment as the old carb along with the 160 main. Thing is it felt loose, like no resistance at all when adjusting the pilot so I was afraid it would come loose out of adjustment so I put a dollop of silicone over the top of the screw just to keep it steady. I rode it last fall and it ran fine but felt just a little more sluggish than before. Now this spring it will only start with full choke, after 30 sec at half choke it pops and sputters with any throttle input, then it starts to die but runs better back on full choke, then sputters with any throttle input, then just dies. After a couple of minutes it starts right up and does the same thing. Any attempt to turn the choke off completely kills it. Im wondering if the new design pilot screw is a larger diameter than the old one, or maybe a new design altogether, maybe I should just slot the "D" topped screw that came with the new carb and use it instead? What did I do wrong? Thanks -
