My control panel (lights, electric start) and neutral light won't work. The neutral light turns on however when I jump start my solenoid. Is this a wiring problem? If so how do I go about checking everything?
Should have a rope (pull starter)Not sure if I have a kickstart
Nearly all batteries will have some kind of writing on them. Next to 12v will be the Ah, so something like, 12v 10Ah.It is a cheap battery from Battery Sharks. It say 12V idk about amperage. I put it on charger and it registered 12V
When i get home i will put sparkplug in and try pull starting it. Also I will look at battery. I may end up taking battery to AutoZone and test it's amperage.Nearly all batteries will have some kind of writing on them. Next to 12v will be the Ah, so something like, 12v 10Ah.It is a cheap battery from Battery Sharks. It say 12V idk about amperage. I put it on charger and it registered 12V
You can’t test a batteries voltage from a charger, it’s just not accurate enough unfortunately, you need a multimeter (voltmeter).
I really think you need to confirm that this ‘cheap’ battery is actually good. Even a scrap battery can read 12v, it’s the Amps that you need to start your ATV.
I’m the mean time all I can suggest is to check all of your earth connections, check all plug connections, switches, fuses etc. Whilst doing this look for damage to the wires and the wiring harness.
Yeah spark plug is black and offly old. When i get home I'm putting new one in, got new one in yesterday.So you have no spark plug in at the moment or are you replacing it because the old one is discoloured or burnt out?
Yes, get your battery ‘drop tested’ (that’s an old term it may not be done in that way now) or the equivalent service that your local store can offer.
