1 - 16 of 16 Posts
ok... I am looking at a 07 rancher 420 4x4 ... at least I thought I was. this is my first bike to purchase.. this bike looks like it has the 400 motor cover.. it don't look like the 420s do.. I don't think its an at though bc it has the electric shifter on the handle bar.. did they make 400s that wasn't at? I'm just trying to figure out what this bike is... it doesn't have a sticker that says at... I uploaded a photo of the bike
He's yanking your chain. Forward him this link if you have to.
It's a 2004 to 2007 Honda Rancher AT. Also known as a Rancher 400. Also known as a TRX400FA or TRX400FGA if it has GPS. It's a 398cc air cooled, carb'd ATV.
The 420's all are 420cc, EFI, and liquid cooled. Have him show you a picture of the engine and carb and then say "gotcha".
It's definitely NOT a Rubicon for many reasons.
And just cause it has the up/down on the left side doesn't make it not an AT. It is an AT because all the AT's can be switched to manual mode and then use the buttons.
it's probably more similar to the Rubicon than the 420 though lol
Agreed, but I focused on the 420 cause that's what the guy was focusing on. Didn't care to get into the details of that gen Rubicon.
Doesn't matter though if this is another join and post in a panic and never hear from again thread...
I’d pretty much bet on that being the case. Oh well
Discussion Starter · #10 ·
... well I probably wont be the most visiting member but I just recently started working on bikes.. no Hondas yet.. I have a Yamaha timberwolf 250 I'm working on currently.. I figured out they didn't make 420 automatics after I did some researching. when I told him what he had, about two hours later he replied " its a 420 though" so I had to research to be sure. thanks for the replies guys. Ill be around probably bc I'm buying me a Honda bike soon.. just trying not to jump into anything.. I'm thinking the new route.. I seen where a 420 rancher was going for under 7k at the dealership with the right options.. what is the ES IRS DPS? those cost more are they just fancy add ons?
That's definitely a 400AT, NOT a 420. I would avoid the 400's. They aren't known for holding up well under anything other than light use. In 2007 the 420 was introduced in footshift and ES models, but the automatic was still the old 400AT. The 420's have front disc brakes and are fuel injected. The 400AT's have front drums and are carb'd. The 400's tend to burn up clutches if you do anything other than ride pastures on them.
IRS-independent rear suspension. Much smoother ride, more ground clearance. Better for everything except towing and heavy hauling, in which case the SRA(solid rear axle) is better IMO.
ES-Electric Shift. This is personal preference, but I avoid them. Footshifts are simple, much less likely to have problems. The ES bikes delete the footshifter and instead have an electric motor on the front of the engine that shifts the bike for you, using buttons on the handlebar. In my opinion, it's just something else to break that isn't really any easier to use than the footshift.
DCT-Dual Clutch Transmission. This is the new automatic transmission Honda started using in 2009 on the Ranchers. It has buttons on the handlebar like the ES, but also has an "Auto" mode which shifts for you. If you don't want a footshift, you might as well skip the ES and get the DCT. If you're going to have all that electronic crap on a bike you might as well have the option of auto or ES.
EPS is electric power steering. I've never seen a need for it but most like it.
I had a 2007 model 420 4x4 ES and I loved that thing. It gave me zero problems and worked like a horse. I took good care of it but I pulled a 60" Swisher finish mower 3 hours a week on STEEP hills at low speeds and it never hiccuped once. Wonderful piece of machinery, plenty of power.
1 - 16 of 16 Posts
