Trx350TE 2006. In process of doing a carburetor cleaning and there's no rubber plug inside the bottom of the unit. Is it needed? Will it cause gas to leak out the overflow? Thanks
YEAH not many things have parts on them you DON"T need to be there to work right?yes, you need that rubber plug !.
What is the purpose of the plug?yes, you need that rubber plug !.
it stops the flow from the jet on the side, if you look below the plug, with out the plug, fuel would bypass the jet.What is the purpose of the plug?yes, you need that rubber plug !.
Thank you sir, I learn something new every day!it stops the flow from the jet on the side, if you look below the plug, with out the plug, fuel would bypass the jet.What is the purpose of the plug?yes, you need that rubber plug !.
ywThank you sir, I learn something new every day!it stops the flow from the jet on the side, if you look below the plug, with out the plug, fuel would bypass the jet.What is the purpose of the plug?
