Cliff notes up front here..And forgive me for the length of this post...
I own..
09 recon 250
09 rancher 420FA
09 Foreman 500ES
Took all 3 in for 20hr service. Recon had a frt mushy brake issue/Foreman was fine/Rancher had occasional stall if you blip the throttle.
First issue is the Recon 250
Explanation for mushy brake was it needed adjustment. The brake worked flawless one weekend and took a dump the following weekend. When I picked it up it was fixed but master cylinder bolts had been messed with and fluid residue all over the top of reservoir. is it possible to adjust and is that how its done? I have worked on cars for almost 20 yrs and something doesnt click. The brake is fixed but it just sounds like bs.
Second issue is the rancher 420
First trip they said they could not duplicate the problem. But when I brought them home I actually got this to stall coming off the trailer. Less than a week later I make a return trip to the stealership. I get a phone call saying that they checked with Honda and this is normal and "do not blip the throttle" and it wont stall. When you are trying to get over a log or rock crawl or do anything that requires just tapping the throttle to clear an obstacle..it will stall about 30% off the time. It will however fire right back up.
Third issue is the Foreman...
Absolutely nothing wrong until 20 hr service completed. Rode twice right after the service and had stumbling and hesitation after warmed up good...say 45min of riding. Mud puddles/up steep hills/starting off in any gear other than first. You would need to wind out every gear as far as possible to avoid/minimize poor performance. They said it was a fouled spark plug...WTF?? 100 miles on the machine and probably 22hrs or so. When asked what caused it...They said blipping the throttle or riding around with the choke on.
Once again sorry for the long post but wanted to provide as much info as possible and i am really pissed at this point.
I own..
09 recon 250
09 rancher 420FA
09 Foreman 500ES
