Yes
Test is in the service manual page 20-10
Download the service manual and check parts links in my signature block below
You want the folder labeled TRX350 Foreman
i dont know how i missed that. I have the manual... so if i hook it up straight to a battery how it shows in the manual i should be ok? or should i use a wire with a fuse on it? if so, what amp fuse? and also when i hook it up on the bench none of the 3 resistance wires will be hooked up to anything so that being said will any LEDs be lit with only the power and ground hooked up?
Not exactly sure I can鈥檛 remember.
Yes use a fuse if you鈥檙e hooking it directly it鈥檚 a 10A 15A circuit and a battery is how many CCA?
but look at the schematic the gauge is a variable sweep
