1 - 2 of 2 Posts
Hi I've got a 2006 rincon 680 efi and suddenly it started acting up it starts and idles fine but as soon as you give more than 1/4 throttle it starts spitting sputtering but won't stall as soon as I let the throttle go it just goes back to idle like nothing is wrong.
Things I've ruled out are
Battery, fuel pump,timing, valve adjustment, coil and wire,spark plug,pcm,angle sensor fuel tank fuel and lines.
Discussion Starter #2
Ok now I've replaced the throttle body with a known good one and still same issue
1 - 2 of 2 Posts
