21 - 28 of 28 Posts
Discussion Starter #21
I'll attempt to take some pictures next week after I get the trailer. I might as well take pictures of the whole rig before it gets dirty.
I am appreciative of all the input, and I'll look into a second battery with an isolator. I'll have to do a little research on the isolator to see where to buy and how to install. I'm sure is simple, but I'll look for some basic instructions which may be included with the isolator. Having an second battery can't be a bad idea - no pull cord like my Foreman. Besides, can you imagine what that battery would mean to someone stranded deep in the woods, far from a WalMart, with a bad battery? It would be nice to be able to bail someone out of a jam.
have you considered a charging pack ?, if need be, you could very easily move it from one place to another to jump start some one. just a thought :).
Discussion Starter #23
It would be great to have some details on that ingenious solution for the heater - sounds like a product opportunity for someone.
I have the Honda Warn winch mount to answer another question, and I have become aware of the need for a second battery. I sure wish Honda would have put in a larger battery like suggested - duh.
I am just getting around to mounting a rear DNR plate on the back on the UTV, and Honda sure didn't allow for that either. I guess I'll make a bracket to fasten over the muffler guard using the guard screws and mount the plate there. With the dump bed, this is a bit of a challenge. A modest amount of thought by Honda would have made this a lot easier too. My decals ended up on my doors which isn't too bad, but again a little thought on Honda's part would have been appreciated. Maybe I expect too much.
Discussion Starter #25
I am the original guy who asked about what heater to consider, but "Jeeown69" was right about the P1000-3 having a hot cab. I've ridden quite a few trails this summer, and the heat in the cab is indeed a problem. I happened to have a full Honda glass windshield with no venting which makes it even warmer. I am no longer considering a heater, and I'll wait until winter before even think about a heater. I have a feeling that the cab will be fairly comfortable w/o a heater with the fabric doors that I'll have on it.
Frankly I am surprised Honda hasn't come up with a venting solution to relieve the heat issue. They did come out with a heat shield of sorts, but it's a economical attempt to resolve a problem that needs more than a fireproof "piece of cardboard." IMHO The shield is standard on the 2018, and I think it's a free "fix" for older P1000's. The seat and your legs get uncomfortably hot as the machine is now even with the "heat shield." We stuff towels around the seats in an attempt to stop some of the heat from getting into the cab. It is not a minor problem. Hopefully in cold weather the problem may be a bit of an asset, but most of our riding is in the summer.
A friends dad bought a P1000 last year, not really sure if its a 16 or 17 though. My friend and i were riding it and i noticed that the heat in the cab was terrible. My buddy mentioned that Honda had a cover or something that is supposed to block the heat. When they brough it in for the post break in service the cover was installed. Ive only rode in it once for a short time since the cover was installed and to me i think it helped alot, quieted the cab down some too. Dont get me wrong you still feel heat but not nearly as much as you did before.
Ive never really looked into it but could there be a aftermarket company that makes a heat shield or something?
You could maybe even try putting some of this on the cover.
https://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K/ref=pd_sim_263_2?_encoding=UTF8&pd_rd_i=B00029KC2K&pd_rd_r=6d798f93-b908-11e8-904f-c52a81cf973c&pd_rd_w=tDc9O&pd_rd_wg=mK0uy&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=56838e6b-66d4-41e0-a762-743f1a1a628a&pf_rd_r=7448DDPSVQE0TGHYQRKT&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=7448DDPSVQE0TGHYQRKT
Wayne
I know this was last addressed 12 months ago but I had to say ... a HEATER? You are taking all the fun out of it. Did grandma and grandpa on their horse and buggy have a heater? No? Do sleigh rides have a heater? No.
I'm glad to hear to decided against the heater.
But. A heat problem. First, take off the doors. I don't think we have winters here like Wisconsin, but I have never seen a side by side here with doors. The whole idea of the thing is ... getting out into nature, and that includes the heat or cold of it.
As to this heat problem, I think it would be solved in the summer if you simply took off the doors. They have a windshield that opens also. I have a neighbor with a 1000. I'll have to ask him about this heat problem.
My neighbor had let me drive his 1000 and it was immense fun, but he has no doors and it ran up the mountain and into the snow real nice. So I know you will be happy with that machine.
dc
Discussion Starter #28
I have a 2018 P1000-3, and I also thought about a heater until I rode in it for awhile. In the summer with the doors on you can't hardly take the heat - I mean hot. You can do a few simple things, and some slightly more complex solutions. The first thing I did was to buy a roll of 1/2" form rubber (from Amazon) with foil backing and made a barrier under the seat the best I could, and that helps quite a bit. Then I bought some Styrofoam pipe insulation material, cut it in half, and pushed it behind the seats. Removing the doors (easy on/off) in a major factor in getting the heat under control I have a full, glass windshield (big mistake) since it won't open. Replacing the windshield may the ultimate solution for me. I also have the cloth uppers on the doors which is naturally the first thing to remove in warmer weather. A lot of guys install a fan (not expensive at all) in the engine compartment, and they say it helps too.
Yes, you can buy a heat shield or make it yourself. You can make it for about $25, and it will be imminently better than the heat shield that was installed by the dealer for your friend. If you make it, just remove the seat, roll out the insulation, and start cutting the general shape. Cut slots for the seat latches, and refine it once you've put the seat back on. I put the seat back on and drew lines to cut on the insulation with a felt marker. It doesn't take long at all, and it does help.
21 - 28 of 28 Posts
