1 - 2 of 2 Posts
If its as you say chain drive and the chain is always coming off or seems loss and is not getting tight there should be 4 main bolts on the rear loosen them and rotate the center hub and see if things become tight there should also be a chain adjuster try that out as well the chain it self could be stretched any photos of said rear end
1 - 2 of 2 Posts
