i have lost all power and do not get even my neutral light to come on. i just rebuilt my engine and put it back together and now have no power.i dint mess with anything electrical so i have no clue what happened,it worked before and now dont. i have a 300 ex trx i would appreciate the help thanks
Are you sure the batt. is not dead? Did you forget to hook up a ground wire? Can you push start it?
It definitely sounds like a battery problem.
I had the same situation last week.
The battery was dead, and after i got it charged it wasnt working because the ground on the battery kept getting disconnected.
I would check the battery, then the battery ground, and then the ground point.
After you do that make sure all your connections to the engine are in the right place if you took the engine out to rebuild it. And check all your grounds for good contact. It should be something simple that you have overlooked.
Agreed^^^^
