you have a few options ?, one: drill the oil drain hole out larger, and tap to a larger bolt ?, two: change oil drain cases ( that's the long and hard way ). three: have a welder, weld some build up on the bottom of the case, and drill/add new threads to the drain hole. stripping out oil drain bolt holes seems to be pretty common around here..lol. and just so you know ?, adding a new oil drain bolt to already stripped threads won't solve your problem !.
