...and I need a hint to fix it.
2016 Rancher 420, totally stock. Original battery. Only 200 miles; I only use it around the acreage.
Last time I put it up after moving snow (about four weeks ago), I left the master switch in the on position. Even better, I set the brake hold, which means the rear brake light was left on. The heated hand grips were in the "Hi" position.
Fast forward to today. Went out to do some chores; spring is coming, or so I'm told. I found the inevitable dead battery. No lights, no dash panel, no nothing. I had to pull my truck up and hook it up to jump it. It would jump and start. But it would die within seconds of unhooking the jumper cables.
I left the truck hooked up to jumper cables for 20 minutes with everything on the Rancher in "off". Same result after starting.
Is there any hope for this battery, or should I cut my losses and just get a new one?
I suppose I could also have an underlying problem in the charging system, but it wasn't acting up at all prior to my screw-up.
Any hints/thoughts appreciated.
