How do remove a 2018 Honda rancher cage on the axle after I got the ball bearing and all that off I have been stuck on this for 2 hours
guessing that is the outer end ?, you don't !!!. they do not come apart like the inner joint does.How do I get this off
noooooooo..you do not !. the outer end does not come apart. the inner joint does. soooooooooo..you break the axle down starting from the inner joint, once thats apart, you remove the outer boot bands, remove the bad boot by sliding it off towards the inner joint end. once its off, you reverse the process, slide new boot on from the inner end, over the cv joint on the outer end, bands, then install small bands on the inner boot, slide boot on, assemble inner joint, install inner bands..walla !.you have to if want to put an outer boot on
