I have a 2016 Honda rancher es 420. I think I wired the winch wrong and now I am getting battery drain. can someone tell me the correct way to wire my winch. I think this is the problem because I can operate winch with key off. thanks.
I wired mine the same to start with and then thought, what if something bridged the live in to a directional pole.... So I fitted the isolation switch.I have my winch hard wired with winch solenoid, inline fuse,so I can use it with key off( and I wanted it this way, even think directions back then told you too
if I recall right))
its been wired this way since 1999, NO power drain at all from winch, and NO issue's other wise either>
Winch only uses power when you press the switch(In/OUT)
NOT saying your's cannot be draining power, but if things are in good working order, it should NOT draw power
things that draw power on NEW atv's are there computers and all there electronic's they have
so like said above, on newer atv's you need to have a tender hooked up, if you don't use the atv regularly and for a while when you do to charge things
you can also use a volt meter to see what is drawing power or not
